Awful noise coming from my Direto XR
detsi1960
Postby detsi1960 » Thu Sep 16, 2021 2:04 pm
There is an awful noise coming from my trainer when I'm pedaling . I've calibrated it and it is level on a trainer specific mat. Any suggestions please?
https://imgur.com/a/A0ouiYO
Re: Awful noise coming from my Direto XR
Postby Elite Admin S » Fri Sep 17, 2021 10:55 am
Please contact our customer care. Specify the trainer model, serial number and add the link of the video:
detsi1960
Postby detsi1960 » Fri Sep 17, 2021 7:22 pm
Thanks I have done that.
hrocs
Postby hrocs » Sun Dec 12, 2021 7:58 am
I had the same sound after 2 winter use, I had to tighten the screw on the flywheel inside, now the sound is quiet perfect.
garciapresa
Postby garciapresa » Mon Oct 03, 2022 9:25 pm
Hi! Have you fixed the problem?
Thanks!!
sbdebuy
Postby sbdebuy » Fri Oct 06, 2023 9:49 pm
J'ai aussi ce bruit similaire serait il pas à cause des roulement du volant le miens date de 2020
Avez vous résolu le bruit si oui comment procéder
Bien sportivement
