Elite Direto Belt Tension
wilforiley
Re: Elite Direto Belt Tension
Postby wilforiley » Sun Dec 13, 2020 1:23 pm
I think the issue is with the black wheel runner. It has too much axial play in the bearing and it doesn’t keep the belt running true on the flywheel. It eventually slips off the black wheel runner and jams in the flywheel.
I’ve even started calibrating mine on every ride and it still keeps falling off. I’ve just wrecked my second belt in as many years. I don’t just want to replace the belt and black wheel again as it’ll keep happening due to the poor design. This is very disappointing when you just want to get on it and ride.
What can be done about this? My trainer is out of warranty now. I’m beginning to wish I had sent it back the first time it did this so I could have got my money back within warranty...
andrew3556
Postby andrew3556 » Mon Jan 24, 2022 10:48 pm
I think there was some mention of greasing the belt.
Never do this or it will slip forever.
Postby Elite Admin S » Mon Jan 31, 2022 2:20 pm
Hi Andrew
The procedure of greasing the belt is done only on the Drivo (and only the toothed belt).
Never do it on Direto!
About wilforiley, please contact the customer care:
vandewielesam
Postby vandewielesam » Sat Nov 04, 2023 3:10 pm
After using my direto for a few years, the belt broke.
I ordered the belt kit with new tension wheel.
I mounted the belt just like the Elite video shows.
I did put the belt to tension just like the video shows.
I calibrated my device.
After riding a few minutes, my belt disconnected and is torn... there goes my 30 euros
old belt
old belt.jpg (74.89 KiB) Viewed 35667 times
new belt with new tension wheel mounted correctly:
new belt.jpg (43.13 KiB) Viewed 35667 times
What should i do now? If i buy new belts, will they keep disconnecting and brake?
steve.hammatt
Postby steve.hammatt » Sun Nov 05, 2023 10:11 am
It sounds like your old belt broke because of a specific problem that affects new belts too, and it wasn't just age. Contact Elite support.
Postby Elite Admin S » Mon Nov 06, 2023 8:46 am
I'm sorry for this inconvenience.
Please contact the support, the guys there will help you solve the problem:
m.smaluch
Postby m.smaluch » Tue Dec 19, 2023 8:52 am
Hello!
Please give me instructions what I need to do to make the trainer work right. I mean showing all parameters correctly (power, speed, distance). For the first time since purchase, I replaced the belt because it broke. After installation according to your instructions, my offset value is 6510, while the default value is 6388. I sent you photos of the trainer sticker and calibration. Please send me tips/steps that I need to do to update the new offset and the trainer measures power correctly.
Postby Elite Admin S » Tue Dec 19, 2023 9:17 am
It's normal to have an offset variation after replacing the belt.
Please follow the instructions you've received and keep the offset you get as your new reference.
m.smaluch
Postby m.smaluch » Tue Dec 19, 2023 12:01 pm
Where can I get the instructions?
The new offset probably affects the power values. I compared it with the power meter in my crank and the difference is 10-20 W.
