I have purchased the pedaling analysis extension. Do I need anything extra for the pedaling analysis to work for the Direto. E.g. External cadence sensor ? Will my Garmin cadence sensor do? Do I need an elite cadence sensor ?
Or should it work by simply connecting to the Direto without any additional sensors ?
I can connect to the Direto fine from app and desktop just the pedaling analysis won't work properly.
Pedaling Analysis Direto
Re: Pedaling Analysis Direto
You shouldn't have any problem without the cadence sensor (it will help to have a more precise result, but it is not necessary).
The only problem that there could be, is that the software won't be capable to understand which pedal stroke is the right/left one.
Can you tell me which problems did you experience with it?
alwyn.jones
That's the problem it didn't seem to show L and R just one line.
Please see attached photos
- Screenshot_20171110-062252.png (60.69 KiB) Viewed 9557 times
- Screenshot_20171110-062308.png (61.79 KiB) Viewed 9557 times
- Screenshot_20171110-062301-min.png (123.65 KiB) Viewed 9557 times
Are you sure to have a updated version of the app?
Are you sure to have selected Direto in the configuration?
