Help deciphering offset code
simonhit
Postby simonhit » Fri Dec 17, 2021 4:54 pm
Trying to recalibrate my Direto after changing the belt...can anyone help me decipher this offset code?!!!
steve.hammatt
Re: Help deciphering offset code
Postby steve.hammatt » Fri Dec 17, 2021 5:22 pm
That does serm rather unclear. 6428 would be my guess.
However, I might be wrong but I thought that code usually either ended in 0 or 5?
simonhit
Postby simonhit » Fri Dec 17, 2021 5:33 pm
Yeah i'm starting to think 6428 too....wonder how much a difference it will make?
Thanks for looking!
Postby Elite Admin S » Mon Dec 20, 2021 12:24 pm
I confirm you that it is 6428.
If you get an offset different of more than 5 points and at the same time you get any issue (slipping at high slope, sudden drop in power, strange noise) then it may be necessary to tighten the belt. But in this case, please contact the support before doing it (the guys there will give you proper instructions)
Users browsing this forum: No registered users and 50 guests
