Which are better Real Software VS My E-Training Desktop and mobile
alvarezkeko
Postby alvarezkeko » Thu Jun 21, 2018 4:12 am
Just as is, which are better Real Software VS My E-Training Desktop and mobile, differences.
Sergio Alvarez
Guerrero, Mexico
Re: Which are better Real Software VS My E-Training Desktop and mobile
Postby Elite Admin S » Thu Jun 21, 2018 10:25 am
Before giving the floor to other users, I'd like to tell you something about our two software.
Real is our old software. The first version was released a lot of years ago.
My e-training Desktop, the new software, is its evolution.
Real will be gradually abandoned. It won't be modified.
The assistance (for bug fixing or problems with OS) is granted til summer 2019.
Also, it doesn't synchronize with my e-training app.
My e-training Desktop instead will get new functions and will be continuously improved during next years.
And it is synchronized with the app.
Now, let's see what other people have to say! ;)
alvarezkeko
Postby alvarezkeko » Wed Jun 27, 2018 8:09 pm
Excellent but when all the Real Software features in My E-Training App? like web races?
Sergio Alvarez
Guerrero, Mexico
Postby Elite Admin S » Thu Jun 28, 2018 12:32 pm
Webraces will be available in my e-training Desktop next fall season ;)
jimkellum
Postby jimkellum » Tue Jul 03, 2018 10:06 pm
I just purchased a new Direto and tried out you so called excellent e-training desktop.
So far I have been unable to complete the protocol configuration because it is not
selectable in either ant or bluetooth. I searched this issue on your forum and it appears
that others had the same issue regardless of type of trainer. So when are you going to
fix this? It useless to tell clients that they have a free year of E-training when they
cannot access it. Get real please and fix your mess or find some competent programmers
who can.
Postby Elite Admin S » Wed Jul 04, 2018 9:55 am
@jimkellum
If you are not allowed to select the protocol, there may be different causes.
First of all, you have to check what is supported by your pc.
About ant+, you have to connect a usb ant+ dongle to the pc. If still the ant protocol is not available:
    - check that the usb dongle has properly been recognized in Windows Device Manager; if not, install manually the drivers (you can find them here: https://drive.google.com/open?id=15jys_ ... fmACnhac3h)
    - check if you have any software that can "occupy" the ant dongle at startup (for example, Garmin Express and other Garmin softwares).
    If it is so, you can uninstall them, check in the option to remove the automatic start or kill the process in Task Manager before running our software
About bluetooth, you have to verify that your pc hardware has the bluetooth LE inside (not only the standard bluetooth).
if it is a Windows pc, it also has to use Windows 10 (the previous os don't support the bluetooth LE).
Please verify all these points and let me know if you're finally able to connect
lellinoaereoplanino
Postby lellinoaereoplanino » Thu Jul 05, 2018 12:59 pm
la app gia' si sincronizza con il sw del pc?
icordo che fino a poco tempo fa se creavo 1 allenamento con l' app non me la ritrovavo nel pc
grazie
sebrios
Postby sebrios » Fri Jul 06, 2018 3:00 am
certo! lápp si sincronizza con il software My-ETrainning.
ma no sincronizza con My Real Software
lellinoaereoplanino
Postby lellinoaereoplanino » Fri Jul 06, 2018 1:17 pm
ho il software My-ETrainning. sul pc a lavoro e purtroppo nn posso creare allenamenti perkeì nn ho il drivo vicino , e senza 1 primo collegamento nn mi apre il sw :(
sarebbe bello poter creare 1 allenamento in ufficio e magari pedalare a casa
lellinoaereoplanino
Postby lellinoaereoplanino » Tue Aug 28, 2018 6:43 pm
lellinoaereoplanino wrote:ho il software My-ETrainning. sul pc a lavoro e purtroppo nn posso creare allenamenti perkeì nn ho il drivo vicino , e senza 1 primo collegamento nn mi apre il sw :(
