FTP statistics does not show in history
Posted: Sun Feb 12, 2023 7:49 pm
by loebbert.sebastian
Good evening
I have done the ftp test and the ftp value is correctly set in the configuration.
Unfortunately, when I now do a training and then open the completed training in the history, the ftp statistics is not shown, as you can see in the screenshot.
In the data summary section, the ftp correctly displayed (see other screenshot).
I run e-training 3.19.2 on an iPad.
What can I do to fix this?
Thanks,
Sebastian
Screenshot showing the missing ftp statistics
Ftp correctly displayed in the data summary section
Re: FTP statistics does not show in history
Posted: Mon Feb 13, 2023 8:25 am
by Elite Admin S
If you use a different device, does the graph appear?
If it is so, uninstall the software and install it again.
If the graph doesn't appear also on the other device, contact the support:
Posted: Fri Mar 03, 2023 9:32 am
Just tried it with another device (iPhone), same issue, will raise a ticket as suggested.
Regards,
Sebastian
Posted: Tue Sep 26, 2023 3:41 am
by clueaxel
loebbert.sebastian wrote:Hi
Just tried it with another device (iPhone), same issue, will raise a ticket as suggested mario games
Regards,
Sebastian
That's right, I also changed the device but the above chart still appears
