I am using the Elite Direto X trainer and using the myETraining app
(paid version). I haven't been for a while
upload / import routes with kml extension. Uninstalling,
updating the application did not do anything, I still get the message:
"the application tried to access sensitive information on yours
Google account. To be sure your account is safe
we blocked this trial. "On the non-paid version
that is, some 2 years ago, we managed to import maps without any problems. On
google email account has no blocking alert
trying to connect. Creating a new gmail account is also fine
change. Besides the problem the application is working properly. I use an android smartphone.
What's the solution to this problem?
Application problem
Re: Application problem
It's due to a change in Drive management made by google.
We are working on a solution
Thank you for your answer. When do you anticipate solving the problem?
I don't have a release date yet, sorry.
I'm also waiting for this solution. How is the correction announced? Is it a release note or just try when there is a new release out?
Same problem here ! Any update ?
Why don't allow local files upload rather then Google drive ?
Thank you.
Thank you.
I confirm you that we have a fix!
The issue will be solved with the new update of my e-training that soon will be released.
Although the problems I reported were different, this message string looks familiar.
Bugs in the software acknowledged, fixes promised, and always the update will be released "soon". That was back in January, and still no update has been released.
Personally I suspect the Elite IT department is over committed and understaffed. A recent video issued by GCN of a visit to Elite's offices showed an IT department comprising four employees. This suggests to me that developing and fixing software does not have a very high priority at Elite.
