Follow the instructions in this link
https://support.apple.com/it-it/guide/m ... h40616/mac
florian.woelfl86 wrote:Hi
on my Mac with macOS Big Sur 11.0.1 I have the same problem.
With the link in the comment above I was able to start the desktop app (that's good). --> hold "ctrl" & "open" the app.
BUT after adding a Trainer the app closes. Even after uninstalling and ne install the same problem. An it seems that the app is still running in the background - looks strange. I am not familiar with Mac compared to the Windows TaskManager where you can close apps manually. Is there any option or does anybody know how to find and uninstall "hidden" app-data?
(for Windows 10 there is a similar problem ...) hopefully Elite can fix this issue soon :/
