Speed indication?
Speed indication?
Hi, a simple question from a brand new user, if I may: Is it possible to show speed in miles per hour mph rather than kph? I am using the Elite Suito. Thanks and regards, Martin
Re: Speed indication?
Of course, you can change the unit of measure in the user settings, where there are the language options
OK thanks. I was originally looking at the My e-training app on my iPhone and language settings do not appear but have just found that it is on the desktop version of the software.
You can find the unit of measure setting also in the app.
You have to select Setting - General to find it
Users browsing this forum: No registered users and 65 guests
