My E Training - None Stop crash Drama
application doesnt work... crashes everytime i try and use the application.... any ideas?
Re: My E Training - None Stop crash Drama
Try uninstalling and installing again the app.
If the problem persists, contact the customer care at myetraining@elite-it.com
I`ve got the same problem uninstalled and reinstalled twice still not working , I am running windows 10 does that make a difference ?
Steve H
Steve H
@rosejsrhill,
contact the customer care you as well, it's necessary to investigate further
rosejsrhill wrote:I`ve got the same problem uninstalled filezilla uc browser rufus and reinstalled twice still not working , I am running windows 10 does that make a difference ?
Steve H
Any update on this ? I have the same problem on a windows 10 laptop. Ive uninstalled several times and still the same, it loads and goes to the Setup screen within the app then just closes.
So frustrating when you spen £850 on a new trainer then the crappy piece of software wont work and the support is rubbish !!!!
If this cant be fixed might take it back and exchange for a Saris !
Tragisch wie viele Nutzer das selbe Problem haben !!!
Neu installieren nützt nichts, nach der ersten Konfigurationsseite schliesst das Programm immer wieder...
Dazu kommt auch immer die Meldung das die Datei ungültig sei...
Für diese Preisklasse doch schon recht schei..e
Tragico quanti utenti hanno lo stesso problema!
Reinstallare è inutile, dopo la prima pagina di configurazione il programma si chiude sempre di nuovo...
Inoltre c'è sempre il messaggio che il file non è valido...
Per questa fascia di prezzo già abbastanza mer..
Tragic how many users have the same problem !!
Reinstalling is useless, after the first configuration page the program always closes again...
In addition, there is always the message that the file is invalid...
For this price range already quite sh..
Idem ne fonctionne pas.
Je viens d'acheter un nouveau Turno et d'installer l'app sur mon pc mais dés que je veux l'ouvrir elle cesse de fonctionnerdirectement!
Hi all, I just managed to make the app work on Windows10. the step I followed, maybe it will work for you:
1) unistall from PC
2)remove from C:\Users\"user_name"\AppData\Roaming the folder named MyETraining
3)installed the app on my iPhone
4)added all the personal setting there, including personal data, hearth beat ranges, trainer/sensors details
5)saved the data
6)download the my training again on the PC (windows 10)
7) the program start just fine, when I reach the first page, which usually cause the program to crash, it worked just fine as all data were already there!!!
8) tried to couple to the trainer (I have a Suito Elite)
IT WORKS!!!!
good luck folks!!!
1) unistall from PC
5)saved the data
IT WORKS!!!!
good luck folks!!!
