battery pack
stefano.berlingeri
battery pack
Postby stefano.berlingeri » Fri Oct 29, 2021 4:10 pm
Hi all,
Someone know if an external battery pack is avaiable for smart trainer? I mean, to avoid connection to AC power?
As for example Zdrive smart trainer? Could the zycle battery pack works on a Direto XR?
https://zycle.eu/en/products/zdrive/
Thank you all.
Re: battery pack
Postby Elite Admin S » Tue Nov 02, 2021 11:36 am
I'm sorry, we don't have any battery pack for our trainers.
Theoretically, if you can find a power battery pack that provides the same output as our power supply (and has the same connector), you could be able to connect it... but it's all theoretical, we cannot guarantee that this will work properly.
