I want to use my e-training on a PC.
When calibrating the device, only the Ant + protocol appears.
Bluetooth is installed and running on the computer. Is it normal for PC only ANT + is available?
regards mariusz
configuration my etraining
Re: configuration my etraining
To connect using bluetooth, your pc must support bluetooth 4.0 or higher.
In your case, probably it's not supported.
