Rename an imported KML
Jinesh
Postby Jinesh » Sat Mar 13, 2021 12:41 am
I have imported a couple of KML tracks from Garmin Connect.
Every imported file is displayed with the title: "Track". Is there a way to rename the imported files ?
https://showbox.tools/
Thanks for help
Cheers,Jinesh,..
Altenburger
Re: Rename an imported KML
Postby Altenburger » Fri Mar 26, 2021 9:58 am
How do you import an rename KML files? I received an error message: No KML File. Also: how can I export map features to a certain kml file?
writemyessayfast
User: North Bay
Postby Elite Admin S » Fri Mar 26, 2021 10:17 am
There's no way to change the title after the import, you have to change the name before importing it
@jinesh,
if you use the pc you can import them directly.
If you use an android phone, you have to insert the file in your gdrive first.
If you use an iOS device, you have to load the file on your iTunes.
ming_ng
Postby ming_ng » Sun Apr 17, 2022 9:06 am
Is there a new way to import KML to an iOS device now? My iPad Mini does not have iTunes, i believe that has been replaced by Apple TV. I can see the KML in Apple Files - i've tried to store it in different locations such as iCloud, On My iPad etc, but the My Training app will not see any available KML files to import. Is there a specific location to save the KMLs on iOS?
