When i send my REAL VIDEO etraining to STRAVA, i can't see the map where i "cycled", only the data....
is it possible to import the map?
So when you did the Ventoux ride you also see the ventoux map in STRAVA?
export training to STRAVA
Re: export training to STRAVA
I'm sorry but by now the export function only consider the training data (speed, power, cadence...) and not the map data (map, altimetry...)
Is it possible that importing map will be possible soon ???
I would like this too, i.e GPS coordinates included in tcx exports. Is there still a plan to fix this, as was informed back in 2015, or did you give it up for some reason?
Is this a problem with Strava not allowing virtual rides?
flavioargent
I wanted altimetry to appear, same as zwift
I would enjoy map datas as well, you really should do this, most of training programs allow it. thx.
david.obber
me too!
it's more than a nice-to-have feature.
The integration with Strava is a great plus for an application, but it should be completed. Does it take a great effort to add gps data to the workout?
I posted about this also, my message has not appeared.
I won't be using myrealvideo anymore, as I need to export map/location, gradient (max, av, etc.) total ascent. These features are all available when I use Bkool, VeloReality, Garmin Connect and BigRingVR.
Me too. No point in data without the map, gradient & ascent data.
@Pancreata,
Sorry, first post in the forum (and also new threads) needs the admin approval (it's not for censoring them, of course, but to avoid phishing and spamming and other weird things). But it's a quite busy period of the year so we don't check the forum posts daily (usually weekly, but it depends).
Users browsing this forum: Google [Bot] and 24 guests
