Elite Suito - Not showing cadence while on Bluetooth
mannypalombi
Postby mannypalombi » Fri Oct 11, 2019 2:15 am
I set up my Elite Suito and everything works fine and connects
Issue is that it shows speed and power, plus provides resistance. It does not show cadence?
I tried on iPhone 11, iPad and Mac.
If I connect it to my Garmin (via ant plus ) everything works fine.
I only have this issue on Bluetooth.
Any suggestions?
hug777
Re: Elite Suito - Not showing cadence while on Bluetooth
Postby hug777 » Tue Nov 05, 2019 5:24 am
I have the Same problème! Do you find solutions?
hug777
Postby hug777 » Tue Nov 05, 2019 5:27 am
I don’t understand that’s the app for that product and it doesn’t work ?
simon.murray
Postby simon.murray » Fri Jan 03, 2020 3:04 pm
If your cadence sensor is Ant+ only (my Garmin one is) you can’t connect it to the app via Bluetooth. You need a separate Ant+ dongle which really would only be used with a computer. When you initially configure your Suito don’t select an external cadence sensor and instead it will use the in-built cadence calculator. It works just as well. I had the same issue and this is how I resolved it. Hope that helps.
