I have an app that I want to be able to use to get a connection status report from a remote query.
I want to know if WiFi is connected, and if data access is enabled over mobile network.
If the WiFi goes out of range I want to know if I can rely on the mobile network.
The problem is that data enabled is always returned as true when I am connected by WiFi, and I can only properly query the mobile network when not connected by WiFi.
all the answers I have seen suggest polling to see what the current connection is, but I want to know if mobile network is available should I need it, even though I might be connected by WiFi at present.
Is there anyway of telling whether mobile network data is enabled without polling to see if is connected?
How to tell if 'Mobile Network Data' is enabled or disabled?
