I'm trying to get the my E-training app working on my Android phone but using both a Wahoo tickr HRM, via Bluetooth and also a Wahoo Speed and cadence sensor, again via bluetooth. My phone doesn't support ANT.
Both sensors connect and i can see them both in the parameters section of the app, but both the trainings and training test apps fail to pick up both sensors at the same time. I can get heart rate working, or cadence if i dont wear the heart rate monitor but never both together. is this a known issue?
Wahoo BT cadence and HR wont work together
Re: Wahoo BT cadence and HR wont work together
Please contact the customer care at myetraining@elite-it.com, it is necessary to investigate further.
is the problem already resolved?
I've got the same issue:
I can get my Turno data into the training app via bluetooth, but Wahoo Tickr (although identified and connected) does not show up.
Thanks in advance for any hints
Harry
Harry
m.elsenaar@gmail.com
Same problem over here. Can you help me set up?
