Cadence
TeMpL
Cadence
Postby TeMpL » Wed Nov 15, 2017 8:57 am
Any chance to get Magene.cn Cadence sensor work properly ?
It connects and its sending dat to my training app if cadence higher than 30... but main problem is if you stop pedaling value no set to 0 but it stays at last displayed value (38 or 72 ... ecet)..
Is this sensor or app problem ?
Re: Cadence
Postby Elite Admin S » Thu Nov 23, 2017 11:56 am
Which transmission protocol does this sensor use? Is it ant+ or bluetooth smart?
richard.jolly
Re: Cadence
Postby richard.jolly » Thu Nov 30, 2017 12:08 pm
I have similar problem. I have a Garmin peddle sensor (ant+) that is detected during the parameter set up on my android phone. The myetraining app returns data during peddling from the misuro sensor on the turbo itself, it returns Hr data but it appears that the cadence data is not being picked up and it just shows 0.
Any suggestions?
Rich
Re: Cadence
Postby Elite Admin S » Fri Dec 15, 2017 12:41 pm
Are you sure that your phone supports the ant+ communication?
If not, you'll have to use a ant+ dongle
Users browsing this forum: Bing [Bot] and 4 guests
