I've watch 935 from GARMIN... Does somebody knows how to connect my watch to my Elite App in order to get pulse in live or connect My Garmin Connect to Elite ?
My E-training connection possible with GARMIN ?
Re: My E-training connection possible with GARMIN ?
I have the Forerunner 255 watch. To get pulse on MyEtraining you either use the Broadcast HR glance each time and pair in Settings. If you have Bike Indoor activity you can set it up to Broadcast HR every time.
The 255 broadcasts on Bluetooth but I think the 935 only has ANT+. So you need the ANT+ dongle on your computer.
I record activities on my watch and load that to Garmin Connect.
How can Garmin Forerunner 255 users effectively integrate their heart rate data with MyEtraining and other fitness platforms?
Do you use a heartrate monitor chest strap or just the watch-style heart rate monitor? maybe myE-Training only works with a chest strap? In my case it works fine with the Garmin HRM-Dual strap (BT and ANT)
To connect your Garmin Forerunner 935 to the Elite app for live heart rate monitoring, first ensure you have the Garmin Connect app installed and synced with your watch. Then, open the Elite app, go to the settings or pairing section,Block Blast and select your Garmin device from the list to establish a connection. Lastly, verify that Bluetooth is enabled on your smartphone and check for any necessary settings in the Elite app to access the heart rate data.
