I have a problem with FTP test Configuration is Direto XRT, PC - win 10, polar hart rate belt, my E training 1.17.1. It seems that all works O:K: except FTP test. After pressing the play button, just don't start. Does anyone have a solution.
Thanks Gregor
FTP TEST
arch.bernardo
Re: FTP TEST
i have the same problem is there a solution?
Re: FTP TEST
Please uninstall the app and install it again.
If still you're having the same problem, contact the support:
Re: FTP TEST
Same problem since update to 1.18
Uninstall and reinstall with no success.
Waiting ideas from support as they state I can´t downgrade to 1.17
corrado.nardi
Re: FTP TEST
Anche io ho lo stesso problema con il FTP TEST di My Etraining. Uno volta premuto il tasto "avvia" il programma non si avvia.
stefan_l_01
Re: FTP TEST
same problem
also calibration does not start direto xr
edit: I coded a ftp test as power/time myself the very same as the ftp test in the app, regarding timing, and I think its even better than the stock ftp test. Because the trainer keeps you on the power you want. If you know your approx ftp, and you target a new one, you can control it much better. For the 20min I coded only 200W as target, to have a more fine resolution increasing the target power with the modifier keys (5% equals 10W then). You can use your best straight gear for all intervals. Give it a try!
Users browsing this forum: Google [Bot] and 6 guests
