Is it possible to create an import GPS course into Training modes, program mode, a new program in My e-training apps?
Import GPS course
Re: Import GPS course
In Real software, it is possible to import gps files. But the course will be imported as a altimetry/distance program (not a geo-located).
In my e-training it is possible to record a gps course or import a gps course from the map courses section (you have to put the file to import in itunes or on your google drive account connected to the smartphone).
andric.sibille
i added course on google my drive as .gpx and .klm file. but it seems that i dont get connection to google. how can i do so?
tpahenriques
Hello everyone,
I found a way to get .gpx files from Ironman website and convert them to .kml that actually work on MyETraining Android App.
1. You get the .gpx file
2. Open Google Drive, go to NEW/More/Google My Maps
3. Import the .gpx file as a layer
4. Export it to KML
5. Put in your google drive and import in the MyETraining App.
For me it works everytime and I could not find it explained anywhere else in the forum.
Hope to help someone with this info.
4. Export it to KML
ivo.vandebroek
Hallo,
Is het niet veel eenvoudiger om gewoon het .gpx bestand te converteren naar .kml met anyconv.com en vervolgens te verplaatsen naar google drive.
Users browsing this forum: Google [Bot] and 6 guests
