Directo XRT and elite Rizer on zwift
Can any tell me what is the best settings to get the most out of the elite Rizer and directo XRT on Zwift for the Rizer for simulation settings please and also the best program on Zwift to get the best use out of these setting? Please regards alan
Re: Directo XRT and elite Rizer on zwift
I'm not sure what you mean by "best settings". I've got an Elite XR-T with a Rizer which I use with Zwift.
Download the Elite Rizer app on your phone and make sure that you set the Trainer Difficulty setting in the Rizer app to the same setting you use in Zwift. This will ensure you get the proper gradient response on the Rizer. You can also turn on "Double negative" slope in the Rizer app to simulate "true" negative gradients in Zwift. I personally don't like the "double negative" setting, so I leave it turned off.
Users browsing this forum: Baidu [Spider] and 14 guests
