Regulate the power
Juan PerRo
Regulate the power
Postby Juan PerRo » Sun Nov 12, 2017 7:37 pm
Hello, I have an Elite Direct roller. I have seen in the Mytraining configuration that you can regulate the power of the roller. Could you explain to me what this regulation is for? Thank you
Re: Regulate the power
Postby Elite Admin S » Thu Nov 23, 2017 11:22 am
Do you mean the power smoothing option?
If it is so, it is used to smooth the power (it does an average calculation on the power values)
Juan PerRo
Postby Juan PerRo » Thu Nov 30, 2017 9:01 pm
Yes, I'm referring to the power smoothing option. I can input a value from 1 to 9. But I don't notice any difference between setting a higher or a lower value.
