Since the last software update, after uploading KML files as a Map Course I'm seeing little 'spikes' in elevation on the route profile that obviously are not 'real'. (see attached example screenshots). These spikes are usually significant in gradient and whilst you might expect to go from 5% to 13% whilst climbing hitting a 15% ramp on a 5/6/7% descent whilst thrashing your 50/11 gear is a bit of an issue.
To narrow down where the problem is I have created KML files s using different file converters and reviewed the same KML files using different KML viewers and it is only when they are imported in to My e-training that the spikes are created.
Anyone have any ideas? Is it just a bug in My e-training?
I'd like to get rid of the issue as it is a real irritation.
Map Courses feature. Spikes in elevation.
- example 2.jpg (154.68 KiB) Viewed 5931 times
- example 1.jpg (174.38 KiB) Viewed 5931 times
Re: Map Courses feature. Spikes in elevation.
It's the first time I see something like that honestly.
Can you tell me exactly the start and stop points so I can do some test?
I have the same problem....
is there a solution???
thanks
thanks
Io ho lo stesso problema, è per caso stato risolto? Confermo che la cosa avviene solo in MYtraining, ho verificato effettuando diversi tipi di smoothing del dato con vari software e con excel.
Dear all,
I've faced the same issue (spikes in the elevation); i've maked some test with different website to make the conversion from gpx to kml. The spikes was solved using mygeodata website --> https://mygeodata.cloud/converter/gpx-to-kml .
Ciao a tutti,
Ho avuto lo stesso problema (picchi nell'altimetria); ho fatto alcuni test con diversi siti web per fare la conversione da gpx a kml. I picchi sono stati risolti usando il sito mygeodata --> https://mygeodata.cloud/converter/gpx-to-kml
Ciao a tutti,
- elevetion spikes.png (246.05 KiB) Viewed 3942 times
Stesso problema anche per me. Esportato la traccia GPS da Garmin e convertito file GPX in KML.
Quando poi importo il percorso in My e-training sul tracciato appaiono picchi di altezza assolutamente inesistenti, e moolto fastidiosi per la pedalata.+
per togliermi la sfizio ho esaminato i dati originali GPX e quelli convertiti KML, e i valori dell'altitudine sono assolutamente lineari, senza sbalzi.
- verifica dati.xlsx
- (128.05 KiB) Downloaded 163 times
- verifica spikes.png (53.22 KiB) Viewed 3536 times
Another solution is to use GPX Smoother to remove the spikes before the KML conversion.
https://www.potter.ca/Biking/smoother/gpxsmoother.html
