Issue with the turno roller
Questions on how to use this forum
nachonuez
Postby nachonuez » Sat Nov 06, 2021 1:26 pm
Hi all,
I was using the roller for my old road bike perfectly of diameter 5mm.
As soon as I tried to change for the new bike (12 mm diameter) I have not been able to do it. I have put the adaptors on both sides and still, the cassette is touching the frame of the bike.
I am not sure what I am doing wrong but I am a little bit desperate, could any one help or advice?
Thank you all,
Nacho
Re: Issue with the turno roller
Postby Elite Admin S » Wed Nov 10, 2021 11:25 am
Is your hub a 12x148mm?
If it is so, you have to purchase this adapter:
https://www.shopelite-it.com/en/sensors ... metrainers
Return to “Forum questions”
