data display delayed turbo muin smart B+
skowalski
Postby skowalski » Sun Oct 14, 2018 9:11 pm
i have bought new turbo muin smart B+ around year ago. i have been using it during winter and it worked fine with the exception of inaccurate data display. that didn't bother me much though.
i haven't used trainer for last few months. when i put the bike on it recently i have noticed that data display is very delayed.
i have setup sensor to 12 blinks but it didn't help.
can you please advise.
many thanks,
Sebastian
Re: data display delayed turbo muin smart B+
Postby Elite Admin S » Fri Oct 19, 2018 10:04 am
Hi Sebastian
Usually this kind of delay is due to interference or bad communication.
Which device are you using to connect?
Can you tell me how much delay you have?
skowalski
Postby skowalski » Tue Oct 23, 2018 1:14 pm
i am using Sony Xperia with Android 8.0.0 with myETraining.
it worked alright before.
i think the delay is growing with passing time. stars probably with around 30s delay and very soon is over 1 minute.
Regards,
Sebastian
Inez527
Postby Inez527 » Sat Jan 05, 2019 10:37 am
I am using an Elite turbo muin B+. But, I am getting a problem. It should be smart trainer control and a delay feeling the hills in Zwift.
Just smooths out the on screen display of power data krogerfeedback.
