i have bought new turbo muin smart B+ around year ago. i have been using it during winter and it worked fine with the exception of inaccurate data display. that didn't bother me much though.
i haven't used trainer for last few months. when i put the bike on it recently i have noticed that data display is very delayed.
i have setup sensor to 12 blinks but it didn't help.
can you please advise.
many thanks,
Sebastian
data display delayed turbo muin smart B+
Re: data display delayed turbo muin smart B+
Hi Sebastian
Usually this kind of delay is due to interference or bad communication.
Which device are you using to connect?
Can you tell me how much delay you have?
i am using Sony Xperia with Android 8.0.0 with myETraining.
it worked alright before.
i think the delay is growing with passing time. stars probably with around 30s delay and very soon is over 1 minute.
Regards,
Sebastian
Regards,
Sebastian
I am using an Elite turbo muin B+. But, I am getting a problem. It should be smart trainer control and a delay feeling the hills in Zwift.
Just smooths out the on screen display of power data krogerfeedback.
Users browsing this forum: No registered users and 49 guests
