Possible to Export (save) Programs?
sebrios
Postby sebrios » Mon Jan 01, 2018 11:46 pm
hello,
I have collected a few workouts I usualy ride.
I will have to format my computer in a few weeks, and I would like to know if there's a way to save these workouts.. (Not the results, but the programs)
I would like to "restore" these programs after the computer is restored or changed.
thanx
SHrider
Re: Possible to Export (save) Programs?
Postby SHrider » Wed Jan 03, 2018 12:35 am
same question from my side...i cant see any points in the software which allows that.....
Postby Elite Admin S » Thu Jan 25, 2018 12:16 pm
It's not possible, sorry.
With my e-training, data are saved on cloud, so no problem.
In Real software, you can save your Data folder (that includes also the trainings you've created).
Run the software, select Settings - Utils - Open Data folder in windows explorer.
That's where the data are saved. Close the software keeping this folder opened. Than, do a backup of this folder.
When you install the software again:
- install all the videocourses first
- then copy the Data folder in the correct position
- finally, run the software
Voilà! :)
SHrider
Postby SHrider » Sat Mar 24, 2018 8:40 pm
Hi Admin,
ok - but how i can bring my Real Software programs (42 self created programs) into the My Etraining Desktop progam?
Postby Elite Admin S » Wed Mar 28, 2018 10:22 am
It's not possible, sorry...
You have to recreate them.
Return to “Software Real”
