"No Competitor Connected" ?
frank.mastrocco
Postby frank.mastrocco » Tue Nov 14, 2017 12:20 am
Just upgraded Real software to V8 and now get Error message "No Competitor Connected". I'm on a wired Axiom and when I disconnect/connect USB I get a tone from computer so I know it's been connected. Where/how do I connect to get my trainer online?
Re: "No Competitor Connected" ?
Postby Elite Admin S » Thu Nov 23, 2017 11:33 am
Please contact our customer care at real@elite-it.com
janet.hatton
Postby janet.hatton » Thu Jun 14, 2018 9:13 pm
I am getting 'no competitor connected to axiom device' when I plug in my real tour wired trainer into my pc. I have just had a Windows update (Windows 8) and a Garmin connect update which is also installed on the pc. Otherwise no issues before. PC does not seem to recognise the trainer but indicates it is connected (tonee following plug in). Any suggestions to solve this problem please?
Postby Elite Admin S » Fri Jun 15, 2018 8:48 am
It seems a problem on the com port.
Please download this file:
https://drive.google.com/open?id=1RNaAY ... 0j2t8BxpMB
Copy it in the same foldere where Real.exe is.
Then run the software.
If the problem is not solved, contact us ar real@elite-it.com
markd74
Postby markd74 » Fri Oct 26, 2018 10:15 pm
Just tried to use my RealTour Trainer after being off it for the summer...I keep getting a 'No competitor connected, You can't access to the course' error. I have tried a number of different things but none have worked. Any suggestions?
Postby Elite Admin S » Thu Nov 08, 2018 1:57 pm
It seems a problem with the com port.
Please follow this procedure:
- download the file at this link: https://drive.google.com/open?id=1k-Ye2 ... yXa6B-Q4GH
- unzip it and copy it in Real folder (in the same place where the file Real.exe is)
- open windows device manager
- check in the COM port list and look for the console COM
- if the number of the port COM of the console is less than 4, please change it and set it at a higher number
- finally, run Real software
Let me know if the problem is solved.
Dirk
Postby Dirk » Wed Nov 14, 2018 10:57 pm
Hello, I had here a "me too".
I downloaded your file, extacted it and put it into the same folder. In fact it is an empty text file with title "BdevExcludeComport3 evite erreurr.txt"
Then my device got found again. So thanks for the help.
Rergards
-Dirk
markd74
Postby markd74 » Wed Dec 05, 2018 5:41 am
Thanks - It worked for me as well!
Return to “Software Real”
