Problem Exporting to Training Peaks
Posted: Tue Feb 28, 2017 12:49 pm
by carlos
Hi, I have a problem, when exporting to training peaks, the speed is too high, the cadence, heart rate, watts seems to be Ok, but not the speed, Is like a unit conversion problem, maybe from KPH to M/s, because In the elite app I have a speed of 35 kph and in training peaks I see 126 kph, that is the same result converting 35 m/s to kph, I also updated the app to the last version today. The problem is still there.
thanks!
Re: Problem Exporting to Training Peaks
Posted: Thu Mar 09, 2017 11:12 am
by Elite Admin M
Are you using the direct export from the app?
Or are you trying to import a .tcx file?
Posted: Mon Mar 13, 2017 10:13 am
by dlask.m
carlos wrote:Hi, I have a problem, when exporting to training peaks, the speed is too high, the cadence, heart rate, watts seems to be Ok, but not the speed, Is like a unit conversion problem, maybe from KPH to M/s, because In the elite app I have a speed of 35 kph and in training peaks I see 126 kph, that is the same result converting 35 m/s to kph, I also updated the app to the last version today. The problem is still there.
thanks!
Garmin <speed>m/s</speed>
myETraining <speed>km/h</speed>
GoldenCheetah - menu Edit -> Fix Speed from Distance recalculates speed to m/s.
