change a course
SHrider
change a course
Postby SHrider » Wed Sep 13, 2017 10:14 pm
one question to a course which was designed by myself. How i can change setting from a self designed course? I cant find a button which allows this....
And i also cant find the PlugIn for import / export data from/to REAL Software.....
Re: change a course
Postby Elite Admin S » Thu Sep 14, 2017 12:05 pm
In Real, select create a new course and then create from existing.
About the import/export, you can find them in the main bar menu under Apps
Return to “Real Software”
Users browsing this forum: Google [Bot] and 8 guests
