I have laptop with Windows 7 / 64 bit.
I intend to buy https://www.bike24.com/1.php?menu=1000% ... uct=206021 USB dongle with the Real software to use it with Qubo digital smart B+.
Is this Real software compatible with my laptop and trainer?
Thanks for the answer!
Real for PC - minimum requirements
Re: Real for PC - minimum requirements
It is compatible, but I suggest you to wait some weeks as we're going to release a new software (compatible also with your trainer) really really soon...
buona sera non riesco a configurare i miei rulli kura sul mio pc ho scaricato mytrainig pero non c e il programma per il kura???dove lo posso trovare grazie
In questo momento il software per pc non supporta i trainer Smart, ma solo gli interattivi.
I trainer smart verranno aggiunti a breve.
