Creating Geo Located Course Issue
petercove
Postby petercove » Thu Jul 20, 2017 12:25 am
I decided to have a go at creating a Geo Located course following the instructions with the Elite real software. The first attempt was a roughly circular course from my home. I got the green start point fixed and then started moving the red finish point. Unfortunately when I moved it about halfway around the course Google Maps suddenly redrew my course using a shorter distance from my home to where I had moved the red marker. Is there a better way to use this feature? I guess it would be OK for non-circular courses. Can we use programs Like Map my ride for example to generate a file for Elite to use?
Re: Creating Geo Located Course Issue
Postby Elite Admin S » Thu Jul 20, 2017 8:54 am
With a little patience you should be able to do it, but I know that sometime it can be frustrating...
Unfortunately it is not possible to import a geo-located course (you can import a kml file, but it will become an altimetry/distance program)
But I also have some exciting news on this topic...
In fall, we will release a completely new pc software (for windows and mac) and the developers has worked also to improve this functionality ;)
So, be patient a little bit more and stay tuned! :mrgreen:
gilles.martel1
Postby gilles.martel1 » Wed Sep 13, 2017 2:09 am
Will it work with Elite Real tour?
Postby Elite Admin S » Wed Sep 13, 2017 9:00 am
Do you mean the new software?
The first release will be available only for fe-c trainers.
Later we will release it also for ant and smart trainers, but I don't have a release date yet.
So, if you have a RealTour B+, it is supported by the new software.
If you have a RealTour ant, it will be supported but you'll have to wait a little for a new version.
If you have a wired RealTour, I'm sorry but it won't be supported.
Nisha Puri
Contact:
Postby Nisha Puri » Mon Dec 11, 2017 12:46 pm
I am looking for best tool which helps me in mining prospect data as per my favorite category/niche.
Sarah777
Postby Sarah777 » Wed Jan 09, 2019 10:40 am
Geolocation brings personalized online training content to your audience, no matter where they are in the world. But how can you use this modern technology in your next online training course? myprepaidcenter activation
jensy
Postby jensy » Sat Jun 29, 2019 12:13 am
Elite Admin S wrote:Do you mean the new software?
Return to “Software Real”
