Real Axiom Wired and Drivo
petercove
Postby petercove » Sun Jul 16, 2017 10:24 pm
I have owned the wired Real Axiom for quite a while and gave it to my wife to use with her 8 speed trail bike. This weekend we purchased the Drivo for her. I uninstalled the original Elite Real software and reinstalled all the Real Videos I had purchased. The Drivo uses the ANT technology.
It is really great (better than my Wahoo Kickr).
I would like to also use the old wired Real Axiom from time to time with my Pinarello Dogma using the same computer (which is connected to a large screen TV) so I can ride those great climbs like Alpe d'Huez etc etc.
My question is will this be possible if I just connect the wires from the Real Axiom to the PC? Do I need anything else? I was going to add myself as an extra rider.
Re: Real Axiom Wired and Drivo
Postby Elite Admin S » Mon Jul 17, 2017 8:20 am
If you want to use different trainers with the same computer, you need a little program called "Real Switcher".
Contact our customer care at real@elite-it.com and ask for it ;)
You'll have to run it before running the software and select the trainer you're going to use. Then, connect your RealAxiom console to the pc and run the software.
Return to “Real Software”
