I was given a wired realaxiom trainer. Running windows 10. I've installed the latest software from the website. I searched the forum for similar issues. My com port is 8. Downloaded the file as suggested in other questions. Still no luck on getting the trainer to connect. What should I try next?
Thank you.
No Device Found
Re: No Device Found
It seems that the system is not able to detect the peripheral and for troubleshooting the problem start the system in the safe mode or switch the bios to lowest sensitivity.
Re: No Device Found
If you still are having problems with the trainer even after following the com port procedure, contact us.
It is necessary to investigate further.
Re: No Device Found
I have also faced the same error with my Epson printer and it cannot be connected after I had changed the Network Adaptor on my system. I have also searched epson printer error code 0xf3, but I found no such benefit from it.
