"No Competitor Connected" ?
frank.mastrocco
Just upgraded Real software to V8 and now get Error message "No Competitor Connected". I'm on a wired Axiom and when I disconnect/connect USB I get a tone from computer so I know it's been connected. Where/how do I connect to get my trainer online?
Re: "No Competitor Connected" ?
Please contact our customer care at real@elite-it.com
janet.hatton
I am getting 'no competitor connected to axiom device' when I plug in my real tour wired trainer into my pc. I have just had a Windows update (Windows 8) and a Garmin connect update which is also installed on the pc. Otherwise no issues before. PC does not seem to recognise the trainer but indicates it is connected (tonee following plug in). Any suggestions to solve this problem please?
It seems a problem on the com port.
Please download this file:
https://drive.google.com/open?id=1RNaAY ... 0j2t8BxpMB
Copy it in the same foldere where Real.exe is.
Then run the software.
If the problem is not solved, contact us ar real@elite-it.com
Just tried to use my RealTour Trainer after being off it for the summer...I keep getting a 'No competitor connected, You can't access to the course' error. I have tried a number of different things but none have worked. Any suggestions?
It seems a problem with the com port.
Please follow this procedure:
- download the file at this link: https://drive.google.com/open?id=1k-Ye2 ... yXa6B-Q4GH
- unzip it and copy it in Real folder (in the same place where the file Real.exe is)
- open windows device manager
- check in the COM port list and look for the console COM
- if the number of the port COM of the console is less than 4, please change it and set it at a higher number
- finally, run Real software
Let me know if the problem is solved.
Hello, I had here a "me too".
I downloaded your file, extacted it and put it into the same folder. In fact it is an empty text file with title "BdevExcludeComport3 evite erreurr.txt"
Then my device got found again. So thanks for the help.
Rergards
-Dirk
Rergards
-Dirk
Thanks - It worked for me as well!
Por fin funciona otra vez increible que solo con un archivo de texto se haya arreglado gracias a quien corresponda.
Jose
Jose
