I have run a pedal analysis and training test within Real software.
Neither test shows in either E-training app or PC history. Where are they?
Is E-training test the same as "real" training test?
Also how do I export Real trainer test as TCX file?
I can only see it as a report for printing only.
The trainer test doesn't show as history on Real. Where is it located?
Real pedal and training test not shown in E-training
Re: Real pedal and training test not shown in E-training
Real software doesn't share the history data with my e-training app, sorry.
But in the app you should find both, the Training Test and the Pedal Analisys (if you have bought it).
To export trainings in tcx format, in Real you have to select Apps - Plugins - Export; then, choose the training you want to export and select the format. In the app, you have to enter the history, select the training, tap on the share button, select export and select the format.
