hello,
I have collected a few workouts I usualy ride.
I will have to format my computer in a few weeks, and I would like to know if there's a way to save these workouts.. (Not the results, but the programs)
I would like to "restore" these programs after the computer is restored or changed.
thanx
Possible to Export (save) Programs?
Re: Possible to Export (save) Programs?
same question from my side...i cant see any points in the software which allows that.....
It's not possible, sorry.
With my e-training, data are saved on cloud, so no problem.
In Real software, you can save your Data folder (that includes also the trainings you've created).
Run the software, select Settings - Utils - Open Data folder in windows explorer.
That's where the data are saved. Close the software keeping this folder opened. Than, do a backup of this folder.
When you install the software again:
- install all the videocourses first
- then copy the Data folder in the correct position
- finally, run the software
Voilà!
Voilà!
Hi Admin,
ok - but how i can bring my Real Software programs (42 self created programs) into the My Etraining Desktop progam?
It's not possible, sorry...
You have to recreate them.
Users browsing this forum: Google [Bot] and 4 guests
