Misuro B+ and Novo Force 8: where to put magnet
martin.beltrop
Hi, I am using Misuro B+ with a brand new Novo Force 8. As I have connection problems (Misuro connects to myETraining but app shows no values when paddling) I am wondering if the magnet that comes with the Misuro needs to be put onto the Novi Force 8. And if so, where to put it? Thanks!
Re: Misuro B+ and Novo Force 8: where to put magnet
Hello Martin!
You will need phillips screwdriver - look for 2 screw on/next to the red roll. Unscrew them, remove the cover and put the magnet there.
It's similar to this video:
https://www.youtube.com/watch?v=-CjO9d1yhe0
Hi! If I don't see these two screws, does it mean that the magnet is already inside the roller, so I don't need to install the one I got with Misuro sensor? I set the diode to one blink, but I can't connect to the app.
.Who is online
