Misuro B+ and Nova Force 8
kreutzer.daniel
Postby kreutzer.daniel » Sun Oct 04, 2020 6:46 pm
Hi there,
I do have Nova force 8 and an Misuro B+, I am wondering how many led blinks I do have to setup? I read sometime 1 or 12 which one is correct?
I am using a 700 / 28c tire and would like to use the zwift app. Someone know how to set it up in the right way?
Thank you and appreciate your help.
Re: Misuro B+ and Nova Force 8
Postby Elite Admin S » Tue Oct 06, 2020 11:43 am
One flash is the correct setting.
You don't have to set a circumference value as the speed is calculated on the roller rotations (not on wheel rotation)
kreutzer.daniel
Postby kreutzer.daniel » Tue Oct 06, 2020 1:44 pm
Oh OK thank you.
This means I do not have to chose the wheel size I need to chose the circumference of the roller?
Where can I find the circumference of the roller?
Thank you very much
Postby Elite Admin S » Wed Oct 07, 2020 8:10 am
Our app and software automatically set it, so you don't have to insert it.
danieboerger
Postby danieboerger » Sat Jan 30, 2021 2:09 pm
I have the same problem here.
My Misuro B+ will not connect to the app, even though it is set to one flash. I connect the home trainer, select bluetooth and begin to pedal, but nothing happens, not even after 5 minutes of pedaling. I tried it with my iPhone and iPad, even disconnected all other bluetooth-devices. Nothing. iPhone is an iPhone 7 on iOS 14.3, iPad 6. generation with iPadOS 14.4. What could be wrong? :?: The Misuro isn't even visible as a device in the phones bluetooth setting.
Thanks in advance,
best wishes,
Daniela
drumazza
Postby drumazza » Fri Feb 12, 2021 4:41 pm
Same problem here. No signs of connection. Is there any support we can contact?
Return to “Misuro”
