Novo force 8 power values
maurocrespi84
Postby maurocrespi84 » Mon Oct 05, 2020 9:06 am
Hi, I just bought a Novo Force 8 and the Misuro B+ sensor. I also downloaded the app MyETraining and correctly connected the trainer. All the values shown (speed, cadence, power, heart rate) are ok, but it seems that the trainer overestimates the power in comparison to the actual effort (the power curves are higher than the actual power). As example, to reach the same level of effort of 200 w on road it is necessary to reach more r less 300 w on the trainer. I don't have a separate sensor to measure the actual power, so I cannot check if the power is really overestimated. Did someone find the same discrepancy?
Thanks,
Mauro
Re: Novo force 8 power values
Postby Elite Admin S » Tue Oct 06, 2020 11:42 am
Please check to have set 1 flash only on the misuro.
Also, check in my e-training to have selected the correct trainer (not, for example, the 5 levels version).
Check also all the other settings.
If all is ok, contact the customer care at myetraining@elite-it.com
maurocrespi84
Postby maurocrespi84 » Wed Oct 07, 2020 11:16 am
thanks for the reply. I checked as you suggested and everything is set correctly (number of flashes, trainer type, etc.). The power indicated still seems to be overestimated compared to the actual effort. I will try to contact the customer care.
Thanks again,
Mauro
Return to “Misuro”
