Misuro b+ battery issue - device not responding
mark_vandenbergh
Postby mark_vandenbergh » Mon Mar 30, 2020 10:43 am
Hi all, bit of help required. I've recently got my trainer out to make the most of this lock down period. I haven't used it in over a year but all was working fine last time out.
I have the Qubo fluid and the misuro b+ device. I went to connect the misuro b+ but noticed no red light when pressing the button. I assumed it was probably the battery so I replaced it with a new one, the light came on, I set it to the number of flashes for my trainer and off I went to connect to zwift, which couldn't detect my device. I tried a couple of times and then thought to check the misuro b+ - no red light when I pressed the button, this seemed odd as it was a brand new battery. I went through the process with another brand new battery and the same thing happened. Any suggestions as to why this is happening? Am I missing something?
Thanks in advance
Mark
Re: Misuro b+ battery issue - device not responding
Postby Elite Admin S » Fri May 15, 2020 12:29 pm
If you use my e-training are you able to connect?
If not, it may be a malfunctioning of the misuro, contact our customer care at myetraining@elite-it.com
Return to “Misuro”
