No place for little magnet in my Arion Mag rollers?
I bought the Misuro B+ for my Arion Mag rollers, but I don't see a cover for a space to install the little magnet on the side of the roller.
Re: No place for little magnet in my Arion Mag rollers?
Not all the Arion Mag are misuro compatible.
You have to check if there's the magnet housing on the central drum (you should see the two screws that lock the housing)
If not, you need to buy the new central drum:
https://www.shopelite-it.com/en/spare-p ... mag-roller
i just got the arion mag rollers too and I see that i have the magnet covering, but it almost seems like there is no magnet there? Where exactly should the misuro b+ sensor be positioned as I cant seem to find this information anywhere.
thanks
nick
thanks
nick
andiyatsia
nick n wrote:Hi,
i just got the arion mag rollers too and I see that i Sarkari Result Pnr Status 192.168.l.l have the magnet covering, but it almost seems like there is no magnet there? Where exactly should the misuro b+ sensor be positioned as I cant seem to find this information anywhere.
thanks
nick
VYou have to check if there's the magnet housing on the central drum (you should see the two screws that lock the housing)
The Misuro cannot be used with interactive trainers such as the Qubo Digital Smart B +. India news is already transmitted from the Saluti trainer card
nick n wrote:Hi,
thanks
nick
Apologies for bumping an old thread - i've got the same problem as the person above. I have installed the magnet but there's no information on where the sensor should go - at a best guess i've put it on top of the frame next to the middle drum so the magnet goes right past it, is this correct?
In the Misuro B+ user manual it's indicated also where the misuro must be placed, look towards the end of the document:
https://drive.google.com/open?id=0B_4_o ... 1Z3eFYwZmM
fincherdavid
- Contact:
regards,
regards,
fincherdavid wrote:it almost seems like there is no magnet there? Where exactly should the misuro b+ sensor be positioned as I cant seem to find this information anywhere.
regards,
The first version of Arion Mag didn't have the magnet housing.
If you want to make it misuro compatible, you have to purchase the drum with the magnet housing.
anveshj34@gmail.com
Thanks for the best solution and i loved it.
