Misuro on Qubo Fluid
I have a problem with de misuro. I buy it last week. I use Zwift, I sinc de Candence/Speed and then de Power. I see on the ElitePower 49648 and Speed/Cadence 49648 with signal. I start pedaling and I do not receive data, the values are 0, and the same with de Garmin Forerunner.
Re: Misuro on Qubo Fluid
First of all, in Zwift connect the Misuro only as a power source (not a cadence/speed source).
If you still have problems on the data, check to have set the correct number of flashes on the Misuro.
Also, check to have positioned the misuro in the correct way (orientation is important!).
If still you're not able to connect, please contact us at myetraining@elite-it.com and add:
- a photo of how the misuro is placed on the trainer
- the screenshots of the configuration you've set in Zwift
