Hi everyone,
I have two problems with Misuro sensor. One of them is the battery life, I changed it last week but it lasts about 4 rides (4 trainig hours aprox)
The second problem is the connection. I can't connectio Misuro sensor with app My E-Training.
I hope your answers. thanks and best regards
Misuro battery life and conncection
Re: Misuro battery life and conncection
Ok, thanks and best regards
kiwisbrown
- Contact:
Allow both vehicles to run connected for about three minutes. Leave the jump-started vehicle running and disconnect the cables in the reverse order that they were attached and close the hoods. Keep the jump-started vehicle's engine running for about a half hour to allow the battery to fully charge.
filmplusapp
filmplusapp
