I am using a Roteo trainer with a Misuro B+ installed on it. I recently replaced my Garmin Edge 520 and connected it to the Misuro and it no longer registers speed while I am on the trainer, just power. I changed the battery on the Misuro but this didn't change anything.
Is this a known issue and are there any known fixes to restore speed measurement when I am using the trainer?
Thanks.
Misuro no longer transmitting speed to Garmin 520
Re: Misuro no longer transmitting speed to Garmin 520
It may be a configuration problem.
If you use my e-training app, all works properly?
I have this same problem both with Trainer Road and Garmin Edge 520. Elite's e-training app works fine so I was thinking does the e-training app calculate speed from the power since it knows trainers power curve?
tallpauld wrote:I am using a Roteo trainer with a Misuro B+ installed on it. I recently replaced my Garmin Edge 520 and connected it to the Misuro and it no longer registers speed while I am on the trainer, just power. I changed the battery on the Misuro but this didn't change anything.
Thanks.
Hi, I have the same problem, but with a Garmin 500 - power is showing, but not speed or cadence.
Do you remember how this got fixed?
Regards,
James.
