Qubo fluid correct setting
jeremyglanfield
Postby jeremyglanfield » Fri Mar 31, 2023 9:13 am
Hey,
Bought a Qubo fluid to train for ride London. Got the additional sensor set is to number 5 for 141mm circumference. But it's recording that I was going 50k in 30 mins. I mean I'd love that to be true. Can anyone shed any light?
jeremyglanfield
Re: Qubo fluid correct setting
Postby jeremyglanfield » Sat Apr 01, 2023 4:47 pm
Ok Scratch that, it was the Garmin app that was putting me at ridiculous speeds that I'm not too bothered about. However - The myEtrainer app is actually making me slower - 8.1k in 34 mins - sweating and panting my way through. Set to 5 blinks. Should I set it to a higher circumference to get the rotation - something like 293mm ....
jeremyglanfield
Postby jeremyglanfield » Sun Apr 02, 2023 10:25 am
I selected power fluid (no Qubo)on the myetraining app and sensor blinker no.5 and it seems to work, at least close to what I feel it should - and then on my Garmin Venu, I set the wheel circumference to 141mm which seems to be a lot better. Probably needs some work, but I think I'm ok with these
Return to “Misuro”
