Upload stuck since a week
Turn your outdoor training into My RealVideo!
bschork
Postby bschork » Tue May 07, 2024 8:51 am
Hi there,
I've recorded a video for myRealVideo-Upload, but the upload is stuck since a week. The id is 242766518. It is stuck at 2,85GB, which is the actual file size, when I check the video in the explorer. But the app calculates 3,38GB to be uploaded.
Anything I can do? The only action available is the delete icon.
Thanks and best regards,
Ben
Re: Upload stuck since a week
Postby Elite Admin S » Tue May 07, 2024 10:09 am
Did you already tried to restart the app?
Also, cancel the upload and try again.
If the problem persists, contact the support:
bschork
Postby bschork » Wed May 08, 2024 8:30 am
thanks and yes. I've restarted both app and mobile several times. "Cancel" is not available, only the trash can is showing. I can click on the video, which will play the video, or I can refresh the page, which will show the turning sign for upload.
I will contact support.
Best regards,
Ben
johannes_merk
Postby johannes_merk » Sat Aug 10, 2024 8:40 am
Are there any solutions? I have the identical issue.
basicpermit
Postby basicpermit » Wed Oct 09, 2024 4:36 am
I am also facing same issue.
Return to “myRealVideo”
