Hi there,
I've recorded a video for myRealVideo-Upload, but the upload is stuck since a week. The id is 242766518. It is stuck at 2,85GB, which is the actual file size, when I check the video in the explorer. But the app calculates 3,38GB to be uploaded.
Anything I can do? The only action available is the delete icon.
Thanks and best regards,
Ben
Upload stuck since a week
Re: Upload stuck since a week
Did you already tried to restart the app?
Also, cancel the upload and try again.
If the problem persists, contact the support:
thanks and yes. I've restarted both app and mobile several times. "Cancel" is not available, only the trash can is showing. I can click on the video, which will play the video, or I can refresh the page, which will show the turning sign for upload.
I will contact support.
Best regards,
Ben
Best regards,
Ben
johannes_merk
Are there any solutions? I have the identical issue.
basicpermit
