I don't cycle on the road anymore but would quite like to record an old route of mine in the car for My RealVideo. Will this work or will a car go too fast for it to record all the inclines etc accurately?
Cheers.
Can I record from a car?
Re: Can I record from a car?
Recording from a car is not a problem, but you should try to keep an appropriate speed.
You should drive with a speed as close as possible to the speed you'd have by bike.
I know that this is almost impossible of course, but try to go slow if you can. Otherwise, the video will be less fluid when you'll reproduce it on your trainer
